WEB API is not running Table 1. WEB API: Scenario 1 Issue Description WEB API is not running Modules Impacted Web API Resolution Steps: Press Win+R and type inetmgr Click OK to open IIS. Figure 1. WEB API is Not Running Expand Sites and click HCLiAutomateWEBAPI. Figure 2. WEB API is not running (cont.) If Start under Manage Website section is enabled, click Start to start the services. If the issue persists, contact the System Administrator.
