404 Resource Not Found
Table 1. iRecommend Components: Scenario 3
Issue Description Error message ‘404 Resource Not Found’ when EntityModel is hit
Modules Impacted EntityModel
Probable Root Cause
  • Paths are not correct in Entity.conf
  • Port is not correct
Resolution Steps:
  1. If the issue is due to the incorrect paths, refer to the resolution steps mentioned for issue in Table 71 .
  2. Also, check if the correct port is being used. To identify the correct port, perform the following steps:
    • Open Entity.conf
    • Search for Listen xxxx
    • example - Here the image below shows the port set for EntityModel component is 9000.
    Listen 9000
    # ports, instead of the default. See also the <VirtualHost>
    # directive
  3. The set port is one where EntityModel is deployed.
