Downloading the Linux™ controller software
Use the Agent Downloads option to run or save the file that is required for installing the Linux™ controller software.
  1. Click Tools > Downloads.
  2. Click Agent Downloads.
  3. Select ibm-trc-controller-9.x.x.noarch.rpm.
    Where 9.x.x is the version that you want to install.
  4. Select Save to save the rpm file.
  5. Use the following command to install the controller software.
    $ rpm -ivh /PATH/ibm-trc-controller-9.x.x.noarch.rpm
    Where PATH is the path to the location that you saved the rpm file to.
