Signed certificate management
By default, BigFix® Remote Control creates a self-signed certificate for the website.
You can change the default certificate by installing your own certificate. For more information about installing a certificate, see Installing a certificate.
The default certificate is in the following directory.
Windows™ systems
\[installdir]\wlp\usr\servers\trcserver\resources\security
Linux™ systems
/[installdir]/wlp/usr/servers/trcserver/resources/security
Where [installdir] is the BigFix® Remote Control installation directory.
The file name is key.jks and has a default password of TrCWebAS.
The configuration for the certificate file is stored in the ssl.xml file in the following directory.
Windows™ systems
Linux™ systems
Where [installdir] is the BigFix® Remote Control installation directory. Any changes to the ssl.xml file are overwritten by configuration changes when you reinstall or upgrade the BigFix® Remote Control server, or rerun trcsetup.cmd.
