Backing up your certificate file
Back up your certificate file if you are upgrading your BigFix® Remote Control server and you previously manually installed a certificate.
The following information applies only when you previously used the server installer to install the BigFix® Remote Control server with an embedded WebSphere® Application Server 8.5 Liberty Profile.
If you are using the default keystore and key.jks file, back up the following file and directory.
Windows™ systems
\[installdir]\wlp\usr\servers\trcserver\resources\security\key.jks
Linux™ systems
/[installdir]/wlp/usr/servers/trcserver/resources/security/key.jks
Where [installdir] is the BigFix® Remote Control server installation directory.
If the default keystore file is not in the default directory or you changed the default keystore password, also back up the ssl.xml file. The file is in the following directory.
Windows™ systems
\[installdir]\wlp\usr\servers\trcserver\ssl.xml
Linux™ systems
/[installdir]/wlp/usr/servers/trcserver/ssl.xml
Where [installdir] is the BigFix® Remote Control installation directory.
Note: If yourkey.jks file is not in the default keystore directory, but is still within the BigFix® Remote Control server installation directory you must back up the key.jks file.
