To add a user to user groups complete the following steps:
- Choose the appropriate method for displaying the user.
Select the user by using the search utility.
- Click .
- The Search User screen is displayed
- Enter the user information in the input field. For the quickest search, type the
users's email address in the Search Users field. You can also type all or
part of the name or any other detail that is known.
- Click Submit.
5) Select the user.
Select the user by using the All Users report.
Select Manage Group Membership from the Actions
list on the left.
Select the user groups that the user must be assigned to.
Any groups with a + sign can be expanded to select sub groups also.
- Click Submit.
The user is a member of the selected groups.
