Key features
Key features of Endpoint Manager Power Management include PC Insomnia Prevention for managing user idle time, Wake-on-LAN Forwarder (WoLF) to enable Wake-on-LAN across subnets, and Last Man Standing (LMS) to ensure at least one active computer for Wake-on-LAN. It also covers Power Management Efficiency, Minimum Power Consumption, and Full Power Consumption metrics.
This section defines the purpose and function of key features of Endpoint Manager Power® Management:
Computers can be set to go into sleep states after configurable amounts of user idle time. The term PC Insomnia is used to describe a situation where applications prevent a computer from sleeping. PC Insomnia Prevention is a mechanism that the BigFix agent uses to monitor user idle time and force the computer to sleep at the appropriate times.
Many enterprise networks do not allow broadcasting from different subnets, which makes Wake-on-LAN difficult. To solve this issue, BigFix agents can be designated as Wake-on-LAN Forwarders (WoLFs), which send the Wake-on-LAN packets to nearby computers in the same subnet. This method allows organizations to use Wake-on-LAN without requiring network changes.
Wake-on-LAN technology requires at least one computer in a subnet to be active to serve as Wake-on-LAN Forwarder for other computers. An LMS-designated computer ensures that a computer is always active by resisting shutdowns and by automatically being awakened if powered off.
Power® Management Efficiency
A measure of how efficiently a computer spends its non-active time, whereby Idle Time is considered inefficient and standby is efficient. The formula is: Standby Time / (Standby Time + Idle Time).
Minimum Power® Consumption
The amount of power used by a computer if it is only powered on when in active use and powered off at all other times.
Full Power® Consumption
The amount of power used if a computer was powered on all day without any power management settings enabled.
