You can create a server installation configuration to use an MS SQL database. You must
install the database, either locally or remotely, and create a database instance before you install
the IBM® BigFix® Remote Control
server.
To create an MS SQL server configuration task, complete
the following steps:
- Select the relevant operating system.
- Enter the installation directory for the IBM BigFix Remote Control server
to be installed to or accept the default that is given.
- Select the relevant MS SQL version and enter the relevant
database parameters.
- Database server address
- The IP address or host name of your database server.
Note: 127.0.0.1 can be used
when MS SQL is installed locally on a Windows™ system
only.
- Port on which to connect to the database
- Port on which MS SQL is installed.
- Name of the Database to use
- Specify the name for the database to be used with the IBM BigFix Remote Control server
- Database Administrator Userid
- Specify the Administrator user ID used for logging on to the database.
The user ID must have admin access to the database.
- Database Administrator Password
- Specify the Administrator password for connecting to the database.
- Path to the JDBC drivers
- Specify the path to the MS JDBC java files. The sqljdbc4.jar
file must be used. The following version of driver can be downloaded from Microsoft.
Microsoft JDBC Driver 4.0 for SQL Server -
sqljdbc_4.0.2206.100_enu.exe.
- If Local, create the database
- If MS SQL is installed locally, you can select to create a blank database during the
installation.
- If Local, drop an existing database
- If MS SQL is installed locally, you can select to drop the database and create a new one. Do not
select drop the database if you are using a remote database.
- New database location (the directory must exist)
- Specify the database installation path. If the installation is local and you
select to create the database the Admin user must have appropriate authority to do so.
- Linux® systems.
- Specify a directory that the admin User ID has read and write permissions for.
- Windows systems.
- Specify an existing directory.
- Enter the relevant server installation parameters as in
step 4
Save your server installation task by following step 5
