Removing the Linux gateway support
You can use the Uninstall IBM® BigFix® Remote Control Gateway support for Linux task to remove the gateway support files from a Linux® computer.
To initiate this task, complete the following steps:
The gateway support files are removed from the selected targets.
Note: After the removal of the gateway support, some files might not be deleted automatically. The
files were created during the installation of the gateway component. The files are in the directory
/opt/ibm and
/var/opt/ibm/trc/gateway.
