Deploying the Linux controller
You can use the Deploy IBM® BigFix® Remote Control Controller for Linux task to install the controller software onto a Linux® computer.
Note: If you are installing the controller on a Red Hat 6.0 64-bit computer the following extra
libraries, along with all their dependencies, must be installed: libXft.i686 libXmu.i686
libXp.i686 libXtst.i686.
To initiate this task, complete the following steps:
