Deploying the Linux gateway support
You can use the Deploy IBM® BigFix® Remote Control Gateway for Linux task to install gateway support onto a Linux® computer.
To initiate this task, complete the following steps:
Gateway support is installed on the targets that you selected when you ran the deployment task. The files are installed in the /opt/IBM/trc/gateway directory on the selected targets.
To use the gateway support, you must set up a gateway configuration for your environment. For more information about configuring the gateway, see the IBM BigFix Remote Control Administrator's Guide.
