Prerequisites for remote target installation
Note: The use of this function in Windows 2008 R2 will be supported in a future release.
To run the remote installation, you also require the following information:
  • Target host name or IP address.
  • The admin user ID used for logging on to the target.
  • The admin password that is used for logging on to the target.
