Collaboration sessions using the server UI
To start a collaboration session when you are logged on to the server UI, start a session with the required target and start collaboration to allow other participants to join the session. The availability of this function is determined by the value set for the Allow multiple controllers server policy. The value that is set for the session is derived from the permissions links that are set up between the user groups and target groups that the controller user and target belong to. For more information on how policies and permissions are derived for a session, see the IBM® BigFix® Remote Control Administrator's Guide.
- Set to Yes
- The Open the collaboration panel for multiple controllers icon is available in the controller session window. Use this to start collaboration sessions. This is the default value.
- Set to No
- The Open the collaboration panel for multiple controllers icon is not available in the controller session window and therefore you cannot start collaboration sessions.
