Using Intel vPro with Wake-on-LAN Medic to wake up endpoints
Follow these steps to set up and schedule endpoints to wake up using the BigFix Wake-on-LAN Medic utility with Intel vPro.
Ensure that you have the following requirements to use vPro with the BigFix Wake-on-LAN (WoL) Medic utility.
  • Subscribe to the latest versions of one of the following sites:
    • BES Support site
    • Power Management site
  • BigFix server requires .NET Framework 2.0
  • Enable the Wake-on-LAN Medic utility. For more information, see Enable Wakeup.
  • Target computers require Intel AMT 3.0 and later versions
  • If Intel Setup and Configuration Servers (SCS) will be used (optional), use SCS Server version 7.0 or later
  • Note:
    Ensure that REST API is set up correctly to avoid errors and for the Wake-on-LAN Medic Utility to function properly. REST API is supported by BigFix server version 9.0 and later.
You can use Intel vPro with the BigFix WoL Medic utility to wake up endpoints. BigFix Power Management uses policies to perform Wake-on-LAN. The policies can be set to wake specific endpoints at specific times and to use vPro.
When the policy is executed, the BESWolMedic.exe utility is invoked to query the applicable endpoints and to send WOL packets.
When the vPro option is enabled, a utility called amtpowercmd.exe uses vPro after successful authentication to send the WoL signal over HTTP to wake up the applicable endpoints.
The BESWolMedic.exe and amtpowercmd.exe are invoked on the BES server.
These steps apply to infrastructures with or without Intel SCS. It is assumed that the vPro infrastructure is set up.
  1. Set up the registry values.
    • With SCS
      For x64
      • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\BigFix\ EnterpriseServer\MFSConfig\PowerWoLSCSServer
        This value is either the host name or the IP address of the server.
      • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\BigFix\ EnterpriseServer\MFSConfig\PowerWoLSCSUsername
      • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\BigFix\ EnterpriseServer\MFSConfig\PowerWoLSCSPassword
      For x86
      • HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLSCSServer
      • HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLSCSUsername
      • HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLSCSPassword
    • Without SCS
      For x64
      • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\ BigFix\EnterpriseServer\MFSConfig\PowerWoLvProUsername
      • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432\ BigFix\EnterpriseServer\MFSConfig\PowerWoLvProPassword
      For x86
      • HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLvProUsername
      • HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\Enterprise Server\MFSConfig\PowerWoLvProPassword
    If you do not use SCS, ensure that the credentials are the same on each endpoint to avoid wake-up failure.
  2. From the BigFix console, select the vPro option in the Wake-on-LAN policy.
    1. Go to the BES Support > Wizards > Schedule Wake-on-LAN wizard.
    2. Create a new policy or select an existing policy.
    3. Select Use Intel vPro technology along with BigFix WoL to wake these computers.
    4. Click Create Policy for new policies, or save the change for existing policies.
      For more information about using the Schedule Wake-on-LAN wizard to create and maintain scheduled wake-ups, see Using Intel vPro with Wake-on-LAN Medic to wake up endpoints.
