System requirements
BigFix Power Management supports various versions of Windows and Mac operating systems, including Windows 7, Windows 10, Windows 11, and macOS 10.15. Users are advised that Windows XP, Windows Vista, and Windows 2003 have reached end of life, and BigFix no longer provides support for products that have reached their end of support date.
BigFix Power Management supports the following Windows™ and macOS™ versions.
Windows
BigFix Power Management supports Windows Server 2008 through 2022 (select versions) for Server editions, and Windows 7 through 11 for Desktop editions. Refer to the following lists for details.
  • Windows Server editions
    • Windows Server 2008
    • Windows Server 2008 R2
    • Windows Server 2012 R2
    • Windows Server 2016
    • Windows Server 2019
    • Windows Server 2022
  • Windows Desktop editions
    • Windows 7
    • Windows 8
    • Windows 8.1
    • Windows 10
    • Windows 11
Mac OS
BigFix Power Management supports macOS version 10.4 and above.
*Windows XP, Windows Vista, and Windows 2003 have reached end of life (EOL). Microsoft products have a lifecycle that ends when the product is no longer supported. When a product reaches EOL or its end of support date, Microsoft no longer supports and releases updates for the product, including automatic fixes, updates, and online technical assistance.
BigFix, in turn, no longer provides security and non-security content and support for products that reached their end of support date. However, users of existing Windows content can use the standard HCL support channels to raise concerns and for troubleshooting support.
Microsoft provides extended support for some products that have reached their end of life. If you signed up for extended support with Microsoft, contact your HCL account representative. To see information about product offerings, see https://www.hcl-software.com/.
