Remotely installing the target software in a peer to peer session
After you have downloaded and installed the Remote Control controller, for using to start peer to peer sessions, you can also use it for remotely installing the target software.
The remote installation function is available in the Configure controller icon in the controller window. It should be noted that this icon is not enabled in the controller window that is used in a remote control session started from the server.
