Remotely uninstalling the target software
When you have installed the target software on a remote target, you can remove the software from this target during a remote control session. Use the Target remote uninstall feature to remove the target software from a remote target computer.
Use the Target remote uninstall option to remotely uninstall the target software while in a remote control session. To remove the target software, complete the following steps:
  1. Click Configure controller > Target remote uninstall.
  2. Select the operating system that is on the target computer.
  3. Enter the relevant target information.
    Target Host
    Enter a host name or IP address for the target you want to remove the software from.
    Target User Name
    Enter an admin ID for the target system.
    When Linux® is selected, the root ID is used by default.
    Target Password
    Enter an admin password for the target system.
    Advanced
    Click Advanced for more configuration options.
    When you select Windows in step 2 the following options are available.
    Remove all instances
    To automatically remove all instances of the Remote Control target software that is contained in the Add Remove Programs section of the Windows® operating system registry, without any user interaction.
    Full registry search
    To search for any Remote Control signatures present in the Windows® operating system registry and not restricted to Add Remove programs only. The list of all instances that are found is displayed. Choose which ones to remove.
    If you choose both options, all instances of the Remote Control target that are found after a full registry search, are automatically removed without any user interaction.
    When you select Linux in step 2 the following options are available.
    Delete backup configuration file
    To uninstall the Remote Control target RPM file and the /etc/trc_target.properties file is also deleted.
  4. Click OK.
  1. If no instances are found in the search, an error is reported.
  2. If you do not select any advanced options the latest level of target software that is installed, is automatically removed.
