Scenario 3 - Web hosting
Figure 1. Webb hosting scenario
In this scenario there are two well defined networks, a secure network where the server is installed and the controllers machines are located and an unsecure network, it could be a web facing network, where servers need to be accessed for maintenance and problem resolution.
The two networks are linked by a DMZ network where two gateways, each with a specific purpose, are installed.
Additionally, HTTP proxies are not available in order to enable the targets in the unsecure network to register in the server in the secure network therefore the gateways need to establish a tunnel connection to allow this communication.
There are two possible scenarios:
Scenario A:
A gateway in the DMZ network is allowed to connect directly to the targets in the secured network (this scenario requires Gateway T1, Gateway T2, T3x and Gateway RC2)
In this scenario, we would add gateway RC1 to the TRC server.
Scenario B:
No traffic is allowed to the DMZ network and the gateway is NOT allowed to connect directly to the targets in the secured network (this scenario requires Gateway T1, Gateway T2, Gateway T3x, Gateway RC1, Gateway RC2 and Gateways RC3x)
The configuration for each scenario would be as follows:
Configuration common to both scenarios
Gateway T1:
  • Create a control connection to Gateway T2 to be used for the tunnel.
  • Create connections to the server for tunnel connections.
Gateway.3.ConnectionType = Gateway
Gateway.3.DestinationAddress = gatewayT2_ipaddress
Gateway.3.DestinationPort = 8881
# Optional:
# Gateway.3.BindTo = 0.0.0.0
# Gateway.3.SourcePort = 0
# Gateway.3.RetryDelay = 45
# Gateway.3.KeepAlive = 900
# Gateway.3.Timeout = 90
# Gateway.3.Passphrase =
Since the targets in the unsecure network cannot connect directly to the server, a tunnel connection must be created that will forward the heartbeats from the targets to the server:
Outbound.1.ConnectionType = OutboundTunnel
Outbound.1.DestinationAddress = trc_server_ip_address
Outbound.1.DestinationPort = 80
# Optional
# Outbound.1.TunnelID = TRCSERVER
# Outbound.1.BindTo = 0.0.0.0
# Outbound.1.Timeout = 90
Where the DestinationAddress and DestinationPort are the IP address and port of the TRC server.
Gateway T2:
Therefore the configuration file for Gateway T2 will contain the following entries, regardless of the type of scenario:
  • Create connections to Gateways T3x
  • Accept control connections from gateway T2.
A gateway connection must be defined for each T3 gateway, that is GatewayT3a, GatewayT3b and GatewayT3c.
Gateway.T3x.ConnectionType = Gateway
Gateway.T3x.DestinationAddress = gatewayT3x_ipaddress
Gateway.T3x.DestinationPort = 8881
# Optional:
# Gateway.T3x.BindTo = 0.0.0.0
# Gateway.T3x.SourcePort = 0
# Gateway.T3x.RetryDelay = 45
# Gateway.T3x.KeepAlive = 900
# Gateway.T3x.Timeout = 90
# Gateway.T3x.Passphrase =
Inbound.1.ConnectionType = Inbound
Inbound.1.PortToListen = 8881
# Optional:
# Inbound.1.BindTo = 0.0.0.0
# Inbound.1.RetryDelay = 45
# Inbound.1.Passphrase =
Inbound.1.AllowGateways = true
Inbound.1.AllowEndpoints = false
Gateways T3x:
The configuration file for Gateways T3x will contain the following entries, regardless of the type of scenario:
  • Accept requests from endpoints for tunnel connections to the server.
# Optional:
InboundTunnel.1.ConnectionType = InboundTunnel
InboundTunnel.1.PortToListen = 8880
# Optional
# InboundTunnel.1.TunnelID = TRCSERVER
# InboundTunnel.1.BindTo = 0.0.0.0
# InboundTunnel.1.RetryDelay = 45
Since the targets in the unsecure network cannot connect directly to the server, a tunnel connection must be created that will forward the heartbeats from the targets to the server.
PortToListen specifies the port that the target should connect to when connecting to the server via a tunnel. For the targets to use the tunnel, the target configuration must set the ProxyURL to:
trcGateway.://<gateway address>:8880
Scenario A
Gateway RC2
Gateway RC2 will have the following configuration:
  • Accept requests from controllers in the secure network.
  • Locate endpoints in the unsecure networks.
# Optional:
Inbound.1.AllowGateways = false
Inbound.1.AllowEndpoints = true
Endpoint.1.ConnectionType = Endpoint
# Optional
# Endpoint.1.SubnetAddress = 0.0.0.0
# Endpoint.1.SubnetMask = 0.0.0.0
# Endpoint.1.BindTo = 0.0.0.0
# Endpoint.1.SourcePort = 0
# Endpoint.1.Timeout = 90
Scenario B
In this scenario, no traffic other than the gateways traffic is allowed outside the secure network. So we need a new gateway RC1 that will accept the requests from the controllers and pass them to RC2. Similarly, we need a new gateway RC3x in each of the unsecure networks to locate the right target.
Gateway RC1:
Gateway RC1 will have the following configuration:
  • Connect to Gateway RC2 to forward the connections requests.
# Optional:
Gateway.RC2.ConnectionType = Gateway
Gateway.RC2.DestinationAddress = gatewayRC2_ipaddress
Gateway.RC2.DestinationPort = 8881
# Optional:
# Gateway.RC2.BindTo = 0.0.0.0
# Gateway.RC2.SourcePort = 0
# Gateway.RC2.RetryDelay = 45
# Gateway.RC2.KeepAlive = 900
# Gateway.RC2.Timeout = 90
# Gateway.RC2.Passphrase =
Gateway RC2
In this scenario Gateway RC2 will have the following configuration:
  • Accept control connections from gateway RC1.
  • Connect to Gateways RC3x to forward the connections requests.
# Optional:
A gateway connection must be defined for each RC3 gateway (RC3a, RC3b, RC3c) where x = a, b or c.
Gateway.RC3x.ConnectionType = Gateway
Gateway.RC3x.DestinationAddress = gatewayT3x_ipaddress
Gateway.RC3x.DestinationPort = 8881
# Optional:
# Gateway.RC3x.BindTo = 0.0.0.0
# Gateway.RC3x.SourcePort = 0
# Gateway.RC3x.RetryDelay = 45
# Gateway.RC3x.KeepAlive = 900
# Gateway.RC3x.Timeout = 90
# Gateway.RC3x.Passphrase =
Gateway RC3x
These gateways are now required to locate the endpoints that before were directly accessible to Gateway RC2. The configuration file for the gateways will contain the following entries:
# Optional:
# Optional
