Setting up a Windows server for exporting recordings
To enable the recording export function on an Remote Control Windows server, complete the following steps
- Download and run the Java™ Media
Framework (JMF) Performance Pack for Windows installer from the following
site
http://java.sun.com/javase/technologies/desktop/media/jmf/2.1.1/download.html - Download and install the Xvid codec from www.xvid.org.
- Stop the Remote Control server service.
- Copy the file jmf.jar from the JMF installation directory to the WEB-INF\lib directory within the BigFix® Remote Control Server installation directory.
If the server version is higher than 10.0.0.0624 and the server is not installed in the
default folder (C:\Program Files (x86)\BigFix), perform the following
steps:
- From the <Install_dir>\TRC\server\wlp\usr\servers\trcserver\apps\TRCAPP.ear\trc.war\WEB-INF\classes folder, open the video.properties file and edit the video.script.path to match your install folder.
- From the <Install_dir>\TRC\server\wlp\usr\servers\trcserver\apps\TRCAPP.ear\trc.war\WEB-INF\rc folder, open the encode.cmd file, and edit servhome to match your install folder.
- Restart the Remote Control server service.
Important:
- The jmf.jar file must be copied again into the WEB-INF\lib, directory whenever the BigFix® Remote Control Server is updated, otherwise the exporting function is disabled.
- If the server is not installed in the default folder, the video.properties and the enode.cmd files need to be changed after the server update.
