Joining or Disconnecting a session
You can configure peer to peer targets so that a controller user can join or disconnect the remote control session that the target is already connected to. For more details of how to use these function see the BigFix® Remote Control Controller User's Guide. Configure the following target properties to enable these features.
Join the session
- Managed = No
- CheckUserLogin=Yes
Collaboration should also be started for the join feature to
be enabled.
Disconnect the session
- Managed = No
- AllowForceDisconnect = Yes
- Set to Yes
- A Disconnect session button is available in the message window that is displayed when you attempt to connect to the target.
- Set to No
- No Disconnect session button is available when you attempt to connect to the target.
- ForceDisconnectTimeout
- Number of seconds you must wait for the current controller to respond to the prompt to disconnect the current session. If they do not respond in the given time, they will be automatically disconnected from the session . The timer takes effect only when AllowForceDisconnect and CheckUserLogin are set to Yes. The default value is 45.
