Logging broker activity
TRCICB-computername-suffix.log
where computername is the computer name of the broker and suffix is determined by the LogRotation and LogRollover settings.
For example, TRCICB-RCBROKER.example.com-Tue.log
The broker log files are located in the \Broker directory within the brokers’s working directory.
In a Windows system, the file is located in \ProgramData\BigFix\Remote Control\Broker\. In Linux the file is located in the /var/opt/bigfix/trc/broker directory.
- Logging level
- Set the required logging level. The logging level determines the types of entries and how
much information is added to the broker log file. Default value is 2.A two column table giving the Logging level parameter values and definitions
Logging Level Description 0 no logging 1 error 2 info 4 debug information - LogRotation
- Controls the period after which an older log file will be overwritten. Log rotation can
be disabled. Default value is Weekly.A four column table giving the LogRotation parameter values and their definitions.
LogRotation Description Suffix for hourly rollover Suffix for daily rollover Daily Overwrite log files after one day 00H to 23H Not valid Weekly Overwrite log files after one week. Mon-00H to Sun-23H Mon - Sun Monthly Overwrite log files after one month. 01-00H to 31-23H 01 to 31 Disabled LogRotation is disabled YYYY-MM-DD-hh YYYY-MM-DD - LogRollOver
- Controls the period after which a new log file is started. This period has to be smaller
than the LogRotation period, therefore not all combinations are valid. LogRollover cannot be
disabled. Default value is Daily.A three column table giving the LogRollover parameter values and their definitions.
LogRollover Description Comments Hourly Start a new log file on the hour. Recommended for busy brokers or when using log levels higher than 2. Daily Start a new log file every day. Default setting. LogRollover Description Comments
Configure the following properties within the trc_broker.properties
file.
For more information about the properties, see Properties for configuring logging activity
- LogLevel
The log level determines the types of entries and how much information is added to the log file. Default value is 2.
- LogRotation
Controls the period after which an older log file is overwritten. Log rotation can be disabled. Default value is Weekly.
- LogRollOver
Controls the period after which a new log file is started. This period must be shorter than the LogRotation period, therefore not all combinations are valid. LogRollover cannot be disabled. Default value is Daily.
- Save the file.
