After a target has registered with the BigFix® Remote Control
Server, you can
assign it to one or more target groups. When the target takes part in a remote control session, the
policies and permissions that are defined for these groups are considered when the final session
policies are derived. For more information about how policies are set for a session, see How policies are determined for a remote control session.
To add a target to one or more target groups, complete
the following steps:
- Choose the appropriate step to select a target:
Select the target by using the search utility
Select the target by using the All targets report.
- Click Targets >All targets.
- Select a target.
Select Manage Group Membership from the Actions
list on the left.
From the group list, select the target groups that you want to add the target to.
Any groups with a + sign can be expanded to select sub groups also.
- Click Submit.
The target is now a member of the selected target groups.
