Designing your scheduling environment
To begin working with HCL Workload Automation you must design your scheduling environment.
- Workstations
- Domains
To create a scheduling environment perform the following actions.
Creating a workstation
You can create multiple workstation definitions.
For more information about the main workstation types and their attributes, see Workstation.
To add a workstation definition to the database and to assign it to a domain, perform the following procedure.Procedure
- From the Design menu, click Graphical Designer page.
- Select a engine from the list.
- Go to the Assets tab, click the + icon, and from the drop-down menu select Workstation.
In the workstations properties panel, specify the attributes for the
workstation you are creating.
In a distributed environment, depending on the type
of workstation you select, some attributes are mandatory.
In a z/OS environment, specify the workstation
attributes using the General, Resources, and Open Time Intervals
tabs as appropriate. Depending on the type of workstation you
To assign the workstation to an existing domain:
- Go to the Domain field.
- Select the domain from the available domains, or click View all and search for the required domain.
- Click the Add button at the end of the properties panel.
enAddWorkstation global option set to
"yes", the workstation definitions are automatically
added to the plan after they are defined in the database.What to do next
To edit a workstation definition in the database and to assign it to a domain, perform the following steps.
- From the Graphical Designer page, select the Assets tab, expand the Workstation section and search for the workstation definition that you want to edit. You can also use the search bar to find the workstation definition to edit.
- Click on the three-dot menu next to the workstation definition and click edit.
- Change workstation information in the properties panel and click Save.
- Select an engine from the list.
- Go to the Assets tab, click the + icon and select Domain.
- In the properties panel that appears on the right, specify domain information.
- Click Add at the end of the properties panel.
Creating a pool of agents
Creating distributed workstation definitions in the HCL Workload Automation database.
To run these job types, you can use , a workstation type that you create by running the related installation process. The are automatically created and registered at installation time. You can also organize the into groups, called pools or dynamic pools.
- Select an engine from the list and create a new Workstation.
In the workstations properties panel, in general information, specify the
attributes for the pool of
you are creating. In the Type drop-down menu, select
Pool or Dynamic Pool,
depending on the set of you
are defining.
- Select Pool to define a cluster of with similar hardware or
software characteristics to submit jobs to. Then, in the Pool
section of the properties panel that displays the that belong to the pool,
click Add worskation to add new or select the bin icon to
remove unwanted .
When dynamic agents are added to a pool, the agent is registered with the pool and this registration is written to the pools.properties file located in TWS_home/ITA/cpa/config. As an alternative method, you can add dynamic agents to a pool by directly editing this file.
- Select Dynamic Pool to define a set of that is dynamically defined based on the resource requirements you specify. In Requirements field, you can specify the requirements necessary for running your jobs. All your selections produce an XML file, which is used to select a workstation with the characteristics you require, to run jobs. When you provide the requirements, you specify a list of workstation candidates to be included in the Dynamic Pool of and the preferred order in which they must be considered. You also specify the best criteria, which is used to change the workstation (workload balance, CPU utilization, or its use of logical resources).
remove unwanted .
- Optionally, you can associate the new pool to a variable table.
- Specify the hosting the workstation.
