Customizing your portfolio
How to customize your portfolio.
Many different elements can be customized in the navigation toolbar across the top and on the left side of you .
You can create a list of your favorite pages, including only the tasks you use most often.
The Favorites icon , lets you access your daily tasks.
To add a task to Favorites, simply click the icon favorite when opening the drop-down menu. To remove an item from your list of favorites, click the icon remove fav.
What to do next
You can also define which pages must be automatically launched when logging into the Dynamic Workload Console by pinning them on the left bar. When the page is opened, click the Overflow menu and pin it.
Customizing your startup page
How to customize the startup page
In the Dynamic Workload Console, you can define the list of pages that are launched, on the left bar, every time you log in to the console. To pin a page on the left bar at every login, click the Overflow menu and then pin it when the page is displayed. Alternatively from the Manage Roles section, users with role Administrator, can add or remove the pinned pages for each role.
Create and customize your boards
In the Dynamic Workload Console, users can create and customize a Board not only with widgets to monitor the scheduling environment but also with web contents. For example, you can add a widget in the dashboard with your company's website and other external contents. see Creating a customized dashboard for monitoring to have your own dashboard.
