Running Workload Automation Programming Language as a load module
In addition to running Workload Automation Programming Language as a compiled REXX EXEC, you can also use the load module EQQWAPL.
- The
MEMBERkeyword ofOISTARTandJSSTARTis not available. You can specify the text for these commands only by using theDLMkeyword, or the respectiveOITorJSTstatement. - The
INCLUDEcommand cannot be used in the formatINCLUDE <DDNAME>(<MEMBER>). You can use other formats, for exampleINCLUDE <DDNAME>andINCLUDE USER_FIELD(<name>). - The
JCLkeyword ofADDJOBis not available. - You cannot use the TSO commands
BULKDISC, DEFINE, DELETE, JSUACT, andREPRO. You can use the PIF version ofDELETEto delete the database and plan objects. - You cannot use the
DYNLOGandXLATEkeywords ofOPTIONS.
Apart from the above limitations, the EQQWAPL load module is equivalent to EQQYXTOP. EQQWAPL is provided for scenarios where you want to call Workload Automation Programming Language from other load modules or exits; in all other cases, you can use EQQYXTOP.
- IKJEFT01 is not run to establish a TSO environment.
- The CMD symbolic points directly to the load module to execute (default EQQWAPL).
- The SYSPROC and SYSTSPRT DD statements are omitted.
//RUNWAPL EXEC EQQYXJPL,
// SUBSYS=WSMC
//SYSIN DD *
ADDJOB ADID(ADHOC)
To call Workload Automation Programming Language from another load module in batch, use the EQQYXJPL procedure. The following example shows the Workload Automation Programming Language step to call Workload Automation Programming Language from another load module. There is no SYSIN DD statement, because the commands are passed to EQQWAPL through a control block.
// CMD=MYPROG,
// SUBSYS=WSMC
| Offset (dec) | Offset (hex) | Length | Type | Field | Description |
| 00 | 00 | 4 | Signed | WPLILINE | Number of 80 byte input lines. |
| 04 | 04 | 4 | Unsigned | WPLIOADR | Address of output data block. Must be initialized to zero. |
| 08 | 08 | 4 | Signed | WPLIOSIZ | Size of output block. Must be initialized to zero. |
| 12 | 0C | 4 | Unsigned | WPLIMADR | Address of message data block. Must be initialized to zero. |
| 16 | 10 | 4 | Signed | WPLIMSIZ | Size of message data block. Must be initialized to zero. |
| 20 | 14 | 80xWPLILINE | Character | WPLICMDS | Each line of WAPL commands. |
Specify the commands to be passed to Workload Automation Programming Language in the
WPLICMDS field. Each line of command text must be long
80 bytes, with normal continuation rules applying; you can use blanks to reach the
required 80-byte length. The WPLILINE field must be set to
represent the number of 80 byte lines, because it refers to the command text in
WPLICMDS. The WPLIOADR,
WPLIOSIZ,
, and
WPLIMADRWPLIMSIZ must be initialized to zero, because they will be
set by Workload Automation Programming Language if
any data is returned.
OPTIONS STRIP(Y) SHOWDFLT(N)LOADDEF AD* DATA(-) LOADER(*)SELECT AD ADID(DAILYPLANNING)
WPLI:
START ADDRESS: 0000CAA0 LENGTH: 0xFC
00112233 44556677 8899AABB CCDDEEFF -0123456789ABCDEF-
000000 00000003 00000000 00000000 D6D7E3C9 *... ........OPTI*
000010 D6D5E240 E2E3D9C9 D74DE85D 40E2C8D6 *ONS STRIP(Y) SHO*
000020 E6C4C6D3 E34DD55D 40404040 40404040 *WDFLT(N) *
000030 40404040 40404040 40404040 40404040 * *
000040 40404040 40404040 40404040 40404040 * *
000050 40404040 40404040 40404040 D3D6C1C4 * LOAD*
000060 C4C5C640 C1C45C40 C4C1E3C1 4D605D40 *DEF AD* DATA(-) *
000070 D3D6C1C4 C5D94D5C 5D404040 40404040 *LOADER(*) *
000080 40404040 40404040 40404040 40404040 * *
000090 40404040 40404040 40404040 40404040 * *
0000A0 40404040 40404040 40404040 E2C5D3C5 * SELE*
0000B0 C3E340C1 C440C1C4 C9C44DC4 C1C9D3E8 *CT AD ADID(DAILY*
0000C0 D7D3C1D5 D5C9D5C7 5D404040 40404040 *PLANNING) *
0000D0 40404040 40404040 40404040 40404040 * *
0000E0 40404040 40404040 40404040 40404040 * *
0000F0 40404040 40404040 40404040
If any data is directed to the REXX stack within EQQWAPL, this data is returned to the calling program in a second control block.
After calling EQQWAPL, the calling load module checks the fields WPLIOADR
and WPLIOSIZ in the WPLI control block. If these fields are set to a value
different from zero, the data has been returned in a second control block WPLO. If messages have
been returned, WPLIMADR and WPLIMSIZ are set to a
value different from zero, and a second WPLO control block containing messages is created.
| 0 | 0 | 4 | Signed | WPLOLINE | Number of WAPL output lines. |
| 4 | 4 | Variable | * | WPLORECS | Block of WAPL output records. |
WPLORECS field is made of
a repeating pair of fields that describe the length and text.| Offset (dec) | Offset (hex) | Length | Type | Field | Description |
| 0 | 0 | 4 | Unsigned | WPLRLEN | Length of WAPL output record. |
| 4 | 4 | Variable | Character | WPLRTEXT | WAPL output text. |
Use WPLIOADR and WPLIOSIZ to get the control
block data, then use WPLOLINE to know how many records to retrieve from
within the data. The first 4 bytes of WPLORECS (the
WPLRLEN field) describes how long the WPLRTEXT field
is, and the offset to the next WPLRLEN field. Repeat this process for the
number specified in the WPLOLINE field.
module and use the WPLI control block, you must include a parameter string when you call EQQWAPL.
The parameter string must include the subsystem name and an INPUT keyword
that includes the address of the WPLI control block. The address must be passed as an 8 byte hex
address prefixed with 0x, for example IWSC INPUT(0x0000CAA0).
Before calling EQQWAPL, the storage for the WPLI control block is obtained within the calling program code. The storage for the WPLO control block is obtained automatically during the running of EQQWAPL. After the control is returned to the calling program, the storage for the WPLI and WPLO control blocks is released within the calling program code.
