Managing workstation definitions
You can create a workstation from the Graphical Designer.
The scope of this scenario is to create a workstation of type Pool, set on the America/New_York time zone.
  1. From the Graphical Designer page, select the Assets tab and click the add icon +.
  2. From the drop-down menu, select workstation.
  3. In General information, from the Type drop-down menu, select Pool.
  4. In Folder, select one of the available folders.
  5. In Name, type the name of the workstation as NEWYORK1.
  6. From the Time zone drop-down menu, select America/New_York.
  7. From the Operating system drop-down menu, select Unix.
  8. In Host or Broken workstation, select the workload broker workstation.
  9. In Pool, click + Add workstation and select the the dynamic agent that you want to add to the pool; you can add multiple members. Then, click Select to confirm the selection.
  10. Click Add.
You have created a Pool workstation, added members to the pool and set the time zone to America/New_York.
