Installaing Detect in Silent Mode
Use the unattended or silent mode to install Detect multiple times.
Before you install Detect, make sure that you have configured the following
elements:
- An application server profile
- A database schema
When you install Detect by using the silent mode, response files are used to obtain
the information that is required during installation. You must create response files
for a silent installation of your product. You can create response files by using
one of the following methods:
- Running the product installers in the GUI (Windows™) or X Window System (Linux™) mode or the console mode before
you install the product in the silent mode. One response file is created for
the Unica suite installer, and one or more response files are created for
your product installer. The files are created in the directory that you
specify.Important:For security reasons, the installer does not save database passwords in the response files. When you create response files, you must edit each response file to enter database passwords. Open each response file and search for PASSWORD to find where you must edit the response file.
When the installer runs in the silent mode, it looks for the response files in the
following directories sequentially:
- In the directory where the Unica installer is saved
- In the home directory of the user who installs the product
Use the following command for Windows™:
HCL Unica_installer_full_name-i silentFor example:
HCL_Unica_Installer_x.x.x.x_win.exe -i silent
Linux™:
HCL_Unica_installer_full_name _operating_system.bin -i silentFor example:
./HCL_Unica_Installer_x.x.x.x_linux.bin -i silent -DUNICA_REPLAY_READ_DIR= /opt/HCL/Silent12 -f /opt/HCL/Silent12/installer.properties
