Post Installation Configurations
After you install Detect, complete post-installation updates for runtime components and configuration files.
After installation, update required runtime artifacts and verify CLI configuration so that the latest server and library components are active.
Runtime Artifact Updates
Replace the existing Detect server archive and related engine libraries with the latest approved versions from your internal delivery source.
If required by your environment, generate client credentials by running ./clientDetails.sh -a UnicaDetect from the Platform tools directory and save the generated client ID and client secret.
CLI Properties Updates
Update the CLI properties file with the correct platform and product endpoint URLs and credentials before running any post-installation commands.
You can validate available CLI commands by running ./CliTool.sh --help.
