How Installers Work
You must use the suite installer and the product installer when you install any Unica product. For example, for installing HCL Detect, you must use the Unica suite installer and the HCL Detect installer.
Ensure that you follow these guidelines before you use the Unica suite installer and the HCL Detect installer:
  • The Unica installer and the HCL Detect installer must be in the same directory on the computer where you want to install the product.
  • The default top-level directory for Unica installations are as follows:
    Operating Systems Top-level Directory Path
    Microsoft Windows C:\HCL\Unica
    Linux-based operating systems /HCL/Unica
    If required, you can change the directory path during installation.
