Tickets stuck in grid - Marked for Release for Actionable
Tickets
Modules Impacted
Release
Resolution Steps:
Ensure that below configuration is completed for Release component. Figure 1. Release
Ensure that Manage Release Rules are configured. If not, follow the
below steps:
Go to Actions > Runbooks > Manage Rules.
Select the Data Source where the organization brings the data from the data
source in BigFix Runbook AI.
Select the Service with which BigFix Runbook AI is integrated and pulls data
for automation.
Click Add New. User will be prompted to enter the Rule Name in dialog box,
and then click Save.
The new rule is added, and it appears in the list of rules. Once the rule is
added, then user needs to set up the configuration parameters for the
rule.
All the existing rules are listed in the tabular view with the
associated parameters and enable user to manage the parameters for
the existing rule.
