Installer exe is not running
Table 1. Product Installer: Scenario 1
Issue Description Installer exe is not running
Modules Impacted Product Installer
Resolution Steps:
  1. Check if antivirus does not stop the exe from running.
  2. Refer to the log and exception files (available where the installer exe has been placed) for more information.
