| Issue Description |
Error message ‘404 Resource Not
Found’ when iKnowledgeScreen is hit |
| Modules Impacted |
iKnowledgeScreen |
| Probable Root Cause |
Paths are not correct in iKnowledgeScreen.conf
Port is not correct
Resolution Steps:
- If the issue is due to the incorrect paths, refer to resolution
steps mentioned in Table - iKnowledgeScreen: Scenario 1
- Also, check if the correct port is being used. To identify the correct
port, perform the following steps:
- Open iKnowledgeSearch.conf
- Search for Listen xxxx
For Example – Here the image below shows the port set for iKnowledgeSearch
component is
9000. #
Listen 9000
# ports, instead of the default. See also the <VirtualHost>
# directive
- The set port is one where iKnowledgeScreen is deployed.
