404 Resource Not Found
Table 1. iCrawler: Scenario 3
Issue Description Error message ‘404 Resource Not Found’ when iCrawler is hit.
Modules Impacted iCrawler
Probable Root Cause
  • Paths are not correct in iKnowledgeCrawler.conf
  • Port is not correct
Resolution Steps:
  1. If the issue is due to the incorrect paths, refer to the resolution steps mentioned for issue a.
  2. Also, check if the correct port is being used. To identify the correct port, perform the following steps:
    • Open iKnowledgeCrawler.conf
    • Search for Listen xxxx
    e.g. – Here the image below shows the port set for iCrawler component is 9000
    Listen 9000
    # ports, instead of the default. See also the <VirtualHost>
    # directive
  3. The set port is one where iCrawler is deployed.
