404 Resource Not Found
Table 1. iScrape: Scenario 3
Issue Description Error message ‘404 Resource Not Found’ when iScript is hit
Modules Impacted iScript
Probable Root Cause
  • Paths are not correct in iScript.conf
  • Port is not correct
Resolution Steps:
  1. If the issue is due to the incorrect paths, refer to resolution steps mentioned for issue in Table 92.
  2. Also, check if the correct port is being used. To identify the correct port, perform the following steps:
    1. Open iScript.conf
    2. Search for Listen xxxx
      example – Here the image below shows the port set for iScript component is 9000.
      Listen 9000
      # ports, instead of the default. See also the <VirtualHost>
      # directive
  3. The set port is one where iScript is deployed.
