Pre-requisites for BigFix Runbook AI Component
This section provides an overview of the prerequisites to run the BigFix Runbook AI installer. Once the infrastructure is ready, determine the server where the installer will be executed. Each type of server – Web Server, Application Server, Advanced AI Server and Database Server have different prerequisites depending on the components being installed. Once you have identified the required servers, components, and the deployment mode, please proceed with the installation of the pre-requisite software and utilities.
This documentation is only for Windows 2012 R2 and higher
versions.
The following table describes the software requirements to install the components.
| Server | Component | Sub-Components | Software Requirements |
| Web Server | Web Component |
| Application Server | Application Component – Microsoft Dot Net |
| Application Component - Python |
| Advanced AI Server | Advanced AI Component - Python |
| Database Server | Database | Transactional Database | MS SQL 2016/2019 /MS SQL 2022 (+) Enterprise / Standard edition 64 bit |
| MongoDB |
MongoDB | MongoDB 8.0.4 |
| SOLR |
SOLR |
| Certificates (applicable for all tiers) | SSL Certificates | ||
