Task Filter
  1. Click Filter () to scale down the search for a task.
    Figure 1. Task Filter
  2. Refer to the below table to understand the fields mentioned in the above figure:
    Table 1. Task Filter
    Fields Description
    Table Name This task filter will work on table where Dynamic data are saved (RequestDetailExtended) in the form of keyName and key value
    Column Name User can apply filter on KeyName or KeyValue of selected table if we consider domain join example; like the KeyName will be “IsDomain Join” and KeyValue should be “yes” or “no” selected by the requester
    Operator Apply operator on task filter like “Not In”, “In”,” CONTAINS”,” EQUALS” etc.
    Column Value Provides the value of column name based on task filter. If we consider domain join example, then Column value will be “yes” or “no”
    Clause Helps to apply more than one condition “OR” and “AND” operators.
  3. Configure the filter as per the task.
  4. If filter is applied on any task, then filter icon gets changed as to notify filter applied.
