Edit/Delete/Move a Task and Move Group
  1. The following actions can be performed on a task:
    Figure 1. Task Actions
    • Edit Task: You can edit the task fields like Task Name, Short task Name, Retry count and Timeout limits etc.
    • Delete Task: You can delete a task from the existing list of tasks by clicking on Delete option.
    • Move Task: You can set the sequence of a task as per the requirement by using icon.
    • Move Group: You can set the sequence of a Group as per the requirement using icon. Same group task will execute parallel.
    • Ungroup task: You can ungroup task by using icon. Users can Ungroup any task above or below the groups.
  2. Once the Template is created, it appears in the Manage Template tab.
