Using the Format Converter node
These instructions describe how to use the Format Converter node in a flow.
To use the Format Converter node:
- Select the Format Converter node from the palette and drag it onto the canvas.
- Right-click on the node to select Settings.
- Configure the node as required, depending upon the data being converted. The following common
properties are available:
- Input Format - Select CSV, JSON, XML or Delimited to correspond to the format of the data that you want to pass to the input terminal of the node.
- Output Format - Select CSV, JSON, XML or Delimited to correspond to the format of the data that you want to pass to the input terminal of the node.
