Flow Command Server
Deploy a flow from the HCL Link Design Server to the local filesystem using Execution flow server definition.
Use the Flow Command Server to override the flow settings and execute the deployed flow from the command line.
When you run a flow, you can perform the following tasks:
Override flow inputs and outputs
Set flow variables
Enable trace
Enable debug mode
Define flow audit option
Define resource file
Set flow execution UUID
Note: The overrides entered when you run a flow do not permanently affect deployed flow
artifacts.
