The documentation provided here describes how to use the Design Server.
This documentation describes Design Server projects.
A flow node invokes a sub flow within a flow. Sub-flows need not be wired to other nodes; it is valid to have a flow that is comprised of multiple sub-flows that each have listeners.
How to use the HCL Link Design Server.
