Output Header
Specifies whether to write a header to the output.
If the Output Header is set, the Join node creates the header.
If the Output Header is set to Header defined in flow variable, the Header Flow Variable property defines the flow variable that defines the header.
If the Output Header is set to Specified Header, the Header property defines the header.
