Flow variables example
See the Flow variables example for a demonstration of how to use flow variables in a flow.
The Flow variables example contains a readme file that contains detailed instructions about how to run the example.
The example is located in the following directory:
install_dir/examples/flowengine/flow_variables
Where install_dir indicates the directory location of the base HCL Link product.
Note: To install this example, as well as the other flow examples, you must install Design Server using the Custom installation.
