Establishing a JDBC connection with HCL OneTest Data
You must establish a connection between HCL OneTest™ Data and the JDBC supported database to generate the schema and to write the generated test data in the database.
You must have created a sample schema in the database. See Creating a sample schema in a database.
  1. Select your project in HCL OneTest™ Server and go to the Data Fabrication page.
  2. Click New from the Connections tab to create a new connection.
  3. Select JDBC as a connection type and click Next.
  4. Enter the following properties of the connection in the Properties dialog box.
    1. Enter the URL of the database.
      For example, jdbc:mysql://10.0.2.15:32768
    2. Enter the name and password to access the database.
  5. Click Test to verify whether the connection is established successfully.
    Note: If the connection fails to establish, it can be because of one of the following reasons:
    • Mismatch in the version of the drivers.
    • Unreachable database.
    • Missing database.
    • Unsuccessful copying of the connector jar file.
You have successfully established the connection between HCL OneTest Data and the database.
What to do next
You must provide a name for the connection, and then generate a schema. See Generating a schema in HCL OneTest Data.
