HCL OneTest Data support to generate test data for SAP BAPI
When you want to generate test data for SAP Business Application Programming Interface (BAPI), you can generate a schema in HCL® OneTest™ Data based on structured schema of SAP BAPI function modules. You can then generate the test data by using the generated schema in HCL OneTest Data.
SAP BAPIs are API methods of SAP Business Object Types. HCL OneTest Data uses SAP BAPI to access the application layer of the SAP System.
Prerequisites
You must have access to Rational® Test Automation Server.
Task flow
You must perform the following tasks in sequence to generate the test data for SAP BAPI in HCL OneTest Data.
The table also provides you the links to the information about the tasks:
Task | More Information |
Install SAP connector files in HCL OneTest Data | |
Establish an SAP BAPI connection with HCL OneTest Data | |
Generate a schema in HCL OneTest Data | |
Generate test data in HCL OneTest Data | Generating test data |
