Schema design overview
When you compose a schema by using HCL OneTest™ Data you must define the types of the schema. You can also modify the types of the schema when you import any schema from local file system or use the schema generated by using any external resource.
You can find information about the tasks that you must perform to design and create the structural view of the schema in your project.
