Configure endpoint connections
To specify an IP subnet in IPv4, you must specify the subnet address and the subnet mask.
prefix.ConnectionType = Endpoint
prefix.SubnetAddress = 198.51.100.0
prefix.SubnetMask = 255.255.255.0
As IPv6 addresses are much longer than IPv4 addresses, the subnet mask notation is not used for IPv6. Both IPv4 and IPv6 support Classless Inter-Domain Routing (CIDR) notation, which specifies the length of the subnet prefix after the subnet address.
prefix.Subnet = 198.51.100.0/24
prefix2.ConnectionType = Endpoint
prefix2.Subnet = 2001:db8:d005:ee::/64
When an endpoint connection is defined in the gateway, by default it tries to locate all endpoints with any IPv4 address.
Previously to configure an endpoint connection for IPv6 the default Subnet had to be overwritten.
prefix.Subnet = \::/0
To configure an endpoint connection that tries to locate all endpoints with IPv6 addresses, you can now use Endpoint6 instead.
prefix.ConnectionType = Endpoint6
