Retrieve user, session, and performance data
The Remote Control User, Session, and Performance Options analysis is used for gathering user interaction, session behavior, and performance property values from targets in your environment. Use the properties to determine what actions the controller user can carry out during a remote control session with this target. For property value definitions, see step 2.
If the analysis is active, the computers that this analysis was relevant for and the values of the user interaction properties are displayed in the Results tab. You can expand the Applicable Computers entry and filter the data further by specific retrieved properties.
