Retrieve session connection data
The Remote Control Target Log (Start/Stop) analysis is used for gathering the audit events from any computers in your environment that have the IBM® BigFix® Remote Control target component installed.
The information is retrieved and updated every 6 hours. The information that is returned by this
analysis is useful for viewing remote control session usage activity on specific targets. Only the
session connection, start, and stop events that are returned for each session. If you require
information about the remote control session activity, use the Remote Control Target
Log analysis.
Note: This analysis is only valid for Windows™ targets.
If the analysis is active, the Results tab lists the computers that this analysis was relevant for. Double-click a computer to see summary data for the selected computer that includes a section for the target log start/stop entries. You can also expand the Applicable Computers entry and filter the data further by specific retrieved properties.
