Creating a favorite targets list
If you access or connect to the same targets regularly, you can create a list of favorite targets. Use the Add to Favourites action to add one or more targets to the list.
To create a favorites list, complete the following steps:
  1. Choose the appropriate method to select the required targets:
    • To select the required targets by searching, follow the steps in Searching for targets, then go to step 2.
    • To select from the All targets list,
      • Click Targets > All Targets.
      • Select the required targets.
  2. Choose the appropriate method to add the target to Favourites.
    • Select Targets > Add to favourites.
    • Select Add to favourites from the Action list on the left
  3. The Favourites screen is displayed listing all targets that have been added to the favorites list.
