Verifying connection information
Use parameters to define how IBM® BigFix® Remote Control connects to the LDAP server. The connection is used to query the LDAP server for the user and group information that is imported into IBM BigFix Remote Control.
Any changes to the ldap.properties file do not take effect until you select Admin,Reset Application. To avoid multiple restarts or an extended outage use an LDAP browser and the LDAP Configuration Utility as an aid to the entire configuration process.
To verify the connection information by using an LDAP browser, define an LDAP server profile by entering the fully qualified host name and credential information. When you open an LDAP browser for the first time, provide details for a new profile.
- Host
- Host name or FQDN of the preferred LDAP Server.
- Port
- Port that is used to communicate with the directory. Typically, port 389 but if your environment contains child domains, port 3268 must be used instead. Port 3268 points to the Global catalog that includes the child domains.
- Base DN
- The root point to bind to the server. For example, DC=mydomain,DC=mycompany,DC=com.
After the information is entered, the LDAP Browser displays attribute names and values available at the root of the Active Directory tree.
When a connection is established, use the same information that is used in the LDAP browser to set the parameters in the ldap.properties file.
- Click
- Select ldap.properties from the list
- When modifications are complete, click Submit
The application must be reset for the changes to take effect. Click or restart the server service.
The properties file can also be edited manually by locating it on the IBM BigFix Remote Control Server. The file is in the [installdir]wlp\usr\servers\trcserver\apps\TRCAPP.ear\trc.war\WEB-INF\classes directory, where installdir is the directory that the IBM BigFix Remote Control Server is installed in. For example, C:\Program Files\IBM\Tivoli\TRC\server\wlp\usr\servers\trcserver \apps\TRCAPP.ear\trc.war\WEB-INF\classes
